Toolbar crash in Staad Pro
Hi everyone,
When I want to draw a beam, I use the toolbar (Add Beam) but I made a mistake.
I drag the toolbar.
I think it will be OK since when we drag the toolbar, the toolbar will be jump up and we can easily fix it by drag it again in where we want to put it.
But in my case, it gave an empty "new" toolbar that even not included in the command View - Toolbars (see picture 1)
if I right click at the Close button, it will give 2 options (Move or Along X{KX})
this option is same with other toolbar, if we click Along X(KX) the normal toolbar will disappear but we can turn it on by command View - Toolbar.
if I click beside the Close button, it will crash (see picture 3).
https://www.dropbox.com/s/lxmwws2pxho3faq/1.jpg
https://www.dropbox.com/s/4gp1vg7kxtj99l0/2.jpg
https://www.dropbox.com/s/8hanxs1ib0okhwg/3.jpg
please your advice about this.
I have re-installed but still got this crash and applied to all Staad file.
please your kindly assistance.
thx a lot
Santo
RE: Toolbar crash in Staad Pro
What exact version of STAAD.pro? Some crashes were resolved with 20.07.09.35, and I can't reproduce your issue with that version.
I tried to press F1 and in the tab What's New my version is V8i 20.07.04
Do you have any suggestion for me to solve it?
Really appreciate that.
Thanks a lot.
I found that it can run normal (modeling, meshing, running program).
But when I click this "new empty" toolbar it will crash and exit.
Santo
Seth, did mean 20.07.09.31? I just looked on your web site and that appears to be the latest.
20.07.09.35 is an internal build that hasn't been released yet, watch the STAAD.pro news feed for notification when it actually gets released. But for the matter at hand, build 31 or 35 should be identical.
