Which brands of ABS are best suited for FDM ?
There are some issues when using ABS for rapid prototyping or rapid manufacturing via fused deposition modelling.
ABS does not stick to any cold surface (requires a heated bed), it warps from the bed (requires extra material as anchor) and it cracks during cooling (requires a heated chamber or at least an enclosure).
I imagine that there are many brands of ABS, which ones can be extruded and among those which ones are known to give the best results in FDM ?
RE: Which brands of ABS are best suited for FDM ?
ABS grades vary widely within the same manufacturer and more so between different manufacturers. I worked at BASF on ABS and related plastics. They make their ABS impact modifier by emulsion polymerization so you get smaller rubber particles and you have a lot residual surfactant which can hinder fusion of the powder in FDM. Dow for example make the impact modifier using a different process giving much larger impact modifier particles and, I think, less surfactant so you could hope for better fusion during FDM.
The short answer is that there are huge differences but I can't tell you right away which is the best one to use. Contact the manufacturers. You can improve the adhesion (ability to stick to a surface) using additives.
Chris DeArmitt
Expert consulting & training
www.phantomplastics.com
Depending on what FDM machine you are using, you may be locked into the proprietary material that the OEM supplies.
