Prevent Area Load on Some Members?
Is it possible to have an area load NOT load some members? For example, I have horizontal bracing in some bays co-planar with the beams and girders. I would like the area loads to distribute to beams and girders only and not to the horizontal bracing.
RE: Prevent Area Load on Some Members?
If you set the member type to HBrace, then it should be ignored for area load attribution. I believe that behavior was established a number of years ago. So, unless you are using a very old version of the program, then you should get the behavior I describe.
