Serial port programming
Hello, I would like to know how to write a programme to
send\receive files over the serial\COM port and which
programming language would be most suitable?
As of now, I'm able write a program to send and receive
characters through the port using a C++ compiler. However,
even after gathering enough info from the help files and
websites to get this far, I still couldn't find anything
on sending files. = \
Anyhow, I would appreciate any info anyone can offer.
Thanks.
DH.
Thanks.
DH.
RE: Serial port programming
i=0;
While (b=file[i++] < 0) {send(b); ); /*** send ***/
i=0;
while (b=receive()>0 ) ( data(i++)=b; ); /*** receive ***/
<nbucska@pcperipherals.com>
My program is only reading around 50k of the file. So my
question is if theres a method of reading large files into
the buffer, or am I just using the wrong commands?
still can't tell it where the EOF is located.
I'm sending the file in binary mode, therfore, what can I
send in binary over the COM that the other computer can
interpret as an EOF command?
Btw, I tried the ASCII '0' suggestion. I'm not sure if I
was doing it correctly, but it kept cutting the file short.
