Adding points to a Studio Spline
I'm not sure why I'm having so much trouble with this, but for some reason I cannot edit a studio spline and add new points into the middoe of it. As a simple example, lets say I have 2 lines that I connect the endpoints of each with a studio spline. So in my dialog box, the list of points shows 2 points. Now, I decide I want a 3rd point in the middle of the line and I define where I want that point to be and move it up above my spline in the part navigator. I try to edit the spline and make that new point be point 2, but if I just click the point, it makes it point 3 and the endpoint of the spline instead of a point along the spline. I can click on the spline and it inserts a point 2 there, but I can only drag it around, not click on my defined point to make it the point 2. What am I doing wrong? Any tips on how to do this, or how to edit the point list in the studio spline dialog box in general would be very helpful! Thanks!
RE: Adding points to a Studio Spline
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Tomas
www.nxjournaling.com
Is there some setting I need to change to get this to work? Other people in my office are unable to do it either and we are all running NX8.
Are these points 1) Poles or 2) Thru Points?
If you are getting "thru points" icon highlighted while editing, you should be able to get the solution with the above suggestions.
If you are getting the "By Poles" icon highlighted while editing, then these points are Poles, or Control points, that will not pass thru the spline. In general poles are the points that give shape to the spline.
Here are couple of scenarios:
1) Editing a Spline created by Thru Points:
By default, NX dialog will show both Thru points icon (first icon) & By Poles icon (second icon).
Make sure that By poles icon is not selected! You can add the points as mentioned above.
Suppose, you have accidentally selected "By Poles" option and tried to edit the spline, and hit OK, next time when you try to edit the spline, you will see ONLY BY POLES ICON highlighted, which means
YOU CANNOT EDIT A SPLINE WITH THRU POINTS OPTION IF YOU HAVE EDITED IT WITH BY POLES OPTION EARLIER! This is old bug in NX.
2) Editing a Spline created by "By Poles" option:
By default, NX dialog will show only By Poles icon (second icon).
You can edit the spline by manipulating Poles, not thru points.
I'm wondering why the WCS was the default selection in the first place. If anyone knows how to change that it would be appreciated, but at least I know how to make it work now. Thanks again to everyone who replied.
