Exclamtion Point on header on NX
Hello, I was wondering if there was a way to tell what part or parts is giving the exclamation point at the top your NX Border. I am using NX85, but I believe it shows up on all recent versions of NX. Please see attached picture.
RE: Exclamtion Point on header on NX
Just a guess, but that might show you.
Also, do a search for "exclamation". You'll get a bunch of stuff.
J
NX 6.0.5.3
I've the same problem.
Out of date column enabled in the assembly navigator, but no clocks in the column.
Used the assembly 'Update Report' information, but I've found one(2) The component version number (as loaded) does not match the version referenced by the assembly and some (4).
What can I do to resolve the only one (2) and which tool can help me to remove the Exclamtion Point on header on NX ?
Thank you...
Using NX 8 and TC9.1
