Camber for Steel Beams on single span, skewed bridge, with vertical curve STARTING intermediate span
Does anyone know of a spreadsheet or software to calculate the cambers for each beam
on a "single span, skewed bridge, with vertical curve STARTING intermediate span". I did my own
spreadsheet but need to check it.
Gary
RE: Camber for Steel Beams on single span, skewed bridge, with vertical curve STARTING intermediate span
Is it some sort of truss or just simple span framing at a skew? Ram Structural System, or the single beam program (Ram SBeam) both handle camber of determinate framing, composite or not if that helps.
Iits single, simple span framing at a skew, with ba vertical which starts between the abutments. I need something which will take care of all the beams as a bridge like this, has different cambers per beam
