Alternative to Nitrided 20MnCr5
Good day everybody,
I've been assigned to a project of a spindle where i need to find a replacer to nitrided 20MnCr5.
The current process:
pre machining of the spindle; quenching and tempering to obtain 25~29 HRc; final machining; surface nitriding (0,3mm) to obtain >650Hv; griding.
My question is if you think AISI 4140 with induction surface hardening could be a alternative to the current process, since we have it with 25~30 HRc, and under hardening conditions ranges from 55 to 60 HRc.
Sorry about the bad inglish, and thanks for any reply.
André
André
RE: Alternative to Nitrided 20MnCr5
Right now i'm testing round samples with 40mm diameter to verify if they can be hardened up to ~57HRc with the ideal depth in the induction hardening machine.
André
