Pl. clarify the exact Dim standard (ASME CODE) for Studs to be used for ASME B16.5 Flanges
Can anybody give me a clear picture of what is the ASME code for Studs to be used in compatible to ASME B16.5 FLANGES?
I am confused because,
If we consider studs, the ASME standard is B18.31.2 for imperial and ASME B18.31.1M for Metric
If we consider Bolts, the ASME standard is B18.2.1 for imperial and ASME B18.2.3 for Metric
But in “Piping Handbook (7th Edition) By: Nayyar, Mohinder L. © 2000 McGraw-Hill”
Chapter 2 - Design Basis, Page B.25, Table B2.2b does not illustrate the standard for Studs.
Request your help in this regards
Kulasera
Kulasera
RE: Pl. clarify the exact Dim standard (ASME CODE) for Studs to be used for ASME B16.5 Flanges
A Handbook is just what it is, a Handbook. The code that you are building to should provide the answer you are looking for.
However, as B16.5-2009 para 6.10 (esp. 610.1) points out;
the word may indicates a recommendation, not a requirement. So, you're free to choose thread type, studlength, etc.
Please bear the B16.5 provided length for stud often is on the small (yet Code compliant), so if you need more thread engagement than 1 thread only, you have to hand calc some stud lengths yourselves.
I agree with XL83NL, the lenghts in 16.5 are usually a little on the short side and normally I used to add 10 - 15mm to all their standard lengths
I would conclude that ASME B16.5 depicts the compatible fastener for the flanges and ASME B18.2.1 and ASME B18.2.2 provides the dimensional standard for the bolt and nut.
