Subrutines DFLUX and FILM
I am calculating with Subrutines DFLUX and FILM temperatures.
My mesh looks like this:
http://files.engineering.com/getfile.aspx?folder=8...
The temperature should be like:
http://files.engineering.com/getfile.aspx?folder=7...
What I get is on the side, where the flux heat is hitting the surface is that:
http://files.engineering.com/getfile.aspx?folder=e...
and on the other side:
http://files.engineering.com/getfile.aspx?folder=b...
As you can see: The "other side" has rounded corners and the the "fluxside" has sharp corners.
I want to avoid those sharp corners.
Does anyone have any clue why this is happening?
I would appreciate any help.
Thank you in advance.
RE: Subrutines DFLUX and FILM
