error in envRunFile
error in envRunFile
Hi guys,
I'm getting this error using abaqus 6.11.5.
Traceback (most recent call last):
File "SMAPyaModules/SMAPyaDriver.mpy/Lib/driverEnv.py", line 276, in envRunFile
File "/homes/abaqus_v6.env", line 148, in <module>
mp_mpi_implementation = PMPI
NameError: name 'PMPI' is not defined
Abaqus Error: Error when reading environment file /homes/sbaqus_v6.env
Abaqus/Analysis exited with error(s).
Does anyone know how to fix it?
If the "PMPI" is not defined how to define it?
Thanks in advance.
Thanks in advance.
RE: error in envRunFile
I'd give it a shot and see if that works.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
would be my guess
I solved the problem.
And yes, Native for windows
PMPI unix based systems.
I had the path to the env file wrong, once I corrected it worked.
