Question about modeling composite beam
I have a some problem about simulating composite beam. In staad composite deck can only subject to posite moment(no tension on the slab), we usually simulate these composite beams with both hinged supported. Suppose there are more than one span of composite supported by girders. How do you guys design the slab over the girder, if using composite deck. No one want to see any crack on the deck. I want to study it more detail including the tranverse shear between the slab and I section. Should I give up the composite deck command and simply simulate it with plate over the i sections. Any suggestions will be appreciated.
RE: Question about modeling composite beam
