ground wire protective coating
Please refer the attached pics. I am looking for a transparent coating material to preventing the ground wire rusting as attached. If possible, is there any recommended? Thank you.
http://files.engineering.com/getfile.aspx?folder=4...
RE: ground wire protective coating
As another option you may keep the actual conductor and cover it by a RTV Silicon Rubber layer.
See-for instance:
http://www.wacker.com/cms/media/publications/downl...
The colour could be a problem in order to meat the Code requirement.
Bill
"Why not the best?"
Jimmy Carter
