Erosion velocity rate in Stainlees Steel 304
Dear All,
Could anybody tell how to calculate the erosion velocity rate (mm/yr) for Stainless Steel 304 ?
Best regards !
Best regards !
RE: Erosion velocity rate in Stainlees Steel 304
Clean water? then it is zero until you get to sonic velocities.
Plymouth Tube
By D2O (heavy water). I want to calculate the erosion on a stainless steel nozzle after 35 years of operation. The velocity of the fluid is 10 m/s.
I need to know which formula or theory should apply for this kind of steel (AISI 304)
Can you help me?
Best regards!
Talk with your flow nozzle supplier. I have heard them say that they have tested many old nozzles and find them to still be in specification.
Plymouth Tube
Yes, it is a Nozzle (not an orifice) attached to a pipeline. The client requested to us to consider the posibility of erosion. I´m quite sure that no erosion could happen there. However, I have to present something (docs, calcs, code, etc) to support my theory of no erosion.
I´m thinking that If I can calculate the erosion velocity rate for AISI 304 will be good enough.
I have the expresion to calculate the erosion rate according Bitter. But the unit of it is mg/g and in not time dependence.
Any idea?
Steve Jones
Corrosion Management Consultant
http://www.linkedin.com/pub/8/83b/b04
All answers are personal opinions only and are in no way connected with any employer.
If there is particulate matter present, that makes all the difference. Erosion-corrosion, i.e. erosion of the passive film leading to corrosive attack, is another matter entirely.
I'll look for it.
Plymouth Tube
Could you find the paper ?
Best regards!
Sorry
Plymouth Tube
You might be able to x-ray the nozzle to confirm you don't have problems either.
Just a thought.
StoneCold
