Stars instead of Digits
Hello Folks,
I am running C2 2013 R1 and got stars instead of digits in my displacement report.
Any idea of the reason.
Thanks in advance for help.
RE: Stars instead of Digits
You have over-filled the field. This usually results from an error that has generated a huge number.
You may overcome this problem by swapping the units with more suitable for the system. Sometimes replacing the length unit "mm" by "m" or "inch" by "ft" can help.
