Catia Macro: How to get Product/Part Object from MyDrawingView.GenerativeBehavior.Document.Parent
Hello World,
This is my first post in this forum. I want to get product/part object to parent document of drawing view. I know we can get full path of the same with following Statement.
MyDrawingView.GenerativeBehavior.Document.Parent.FullPath
But I have following problems
1. How can I get object to Parent 3D model without opening it ?
2. How to find if 3D Parent Model is already opened and switch to same ?
Jagandeep
RE: Catia Macro: How to get Product/Part Object from MyDrawingView.GenerativeBehavior.Document.Parent
Welcome to Eng-Tips....
1.
CODE --> CATScript
' Get the document from the view
  Set oDocToOpen = MyDrawingView.GenerativeBehavior.Document.Parent
  ' open the document
  OpenDoc(oDocToOpen.FullName)
  'Activate the opened document if already opened
  oDocToOpen.Activate
2.
Send the full name of the linked file to this function. it check the documents opened if opened then
CODE --> CATScript
' Opens a document
'	 Input 	- Document's Full Name with path
' 	 Output	- Document opened and activated
Function OpenDoc(oDocName)
	' Declaration
	Dim oProdFile
	If (NOT(Len(oDocName) = 0)) Then
		If (NOT(IsOpen(oDocName))) Then
			Set oProdFile = CATIA.Documents.Open(oDocName)
			oProdFile.Activate
		End If
		Set oProdFile = Nothing
	End If
End Function
' Check the document is open or not
'	Input 	- Document's Name with or without filepath
' 	Output	- TRUE, If Document is opened already in session
'		- FALSE, If not opened
Function IsOpen(ByVal oDocName)
	IsOpen = FALSE
	' Declaration
	Dim oTmpWnds, oTmpWnd
	Set oTmpWnds = CATIA.Windows
	oDcNm = Right(oDcNm, Len(oDocName) - InStrRev(oDocName, "\"))
	If NOT(oTmpWnds.Count = 0) Then
		For Each oTmpWnd in oTmpWnds
			If (UCase(oTmpWnd.Name) = UCase(oDocName)) Then
				IsOpen = TRUE
			End If
		Next
	End If
	Set oTmpWnds = Nothing
	Set oTmpWnd = Nothing
End Function
Maddy
Thanks Dear. You saved my day. Thanks a Lot
You are welcome..
Maddy
The willingness to share knowledge does not make one charitable; it makes one self-reliant to know more.
Modified - Courtesy of Robert Brault
