line pipe used in place of seamless pipe
can we use line pipe(HFW) in place of seam less pipe at launcher station piping?
IN ASME 31.3 is there any recomadation to use line pipe inplace of seamless pipe
Thanks & Regards
chan
RE: line pipe used in place of seamless pipe
I can't see any reason why not. However be aware that if your piping is 31.3, hopefully not the pipeline piping, you either need to move the code break or calculate the wall thickness differently. 31.3 doesn't recognise the extra SMYS of line pipe so you need to be careful when swapping one pipe for another.
API 5L and 5LX pipe may be used in pipe under B31.3 in accordance with the design allowable stresses listed therein. B31.3 does not "recommend" the use of either over another.
