Bracing Connections
Bracing Connections
Can diagonal bracing be attached eccentrically to a column? For example, could a gusset plate be fastened to the flange of a column flat side to flat side? I would imagine that if this were allowed then the column would have to be checked for a localized torsion at the location of the gusset and stiffening of the column at that location may be required.
RE: Bracing Connections
