Bolt pre-load
Bolt pre-load
I have an ABAQUS input deck which I'm running through the batch command (I do not have ABAQUS CAE).
I have got 4 steps defined.
In the first step I have the bolt pre-load defined (CLOAD OP=NEW)
In the second step I define the external load of 25000 (CLOAD OP=MOD). I put OP=MOD because I want the existing loads to be retained in the second step.
Then, in third step, I want the external loads to be incremented by 25000, Again I put CLOAD OP=MOD
Is this ok?
That is,
1) in the irst step, I have:
*CLOAD
1000002, 1, 3.000000E+07
**%Comment Bolt Pre-Load_abaqus_3 (Abaqus3DBoltPreLoadForce)
*CLOAD
1000011, 1, 3.000000E+07
**%Comment Bolt Pre-Load_abaqus_2 (Abaqus3DBoltPreLoadForce)
*CLOAD
1000013, 1, 3.000000E+07
2) In the second step, where I defined an external load of 25,000 (I want to retain the bolt preloads)
**%Comment 25000 N (NormalForce)
*CLOAD, OP=MOD
3) Similarly, in the 3rd step
*CLOAD, OP=MOD
Is the process 1,2,3 correct?
That is:
A) In first step only bolt preload
B)Second step 25000 ext load
C) Third step 25000 incremented (total ext load in second step = 50000)
IS the process correct (from ABAQUS syntax point of view)
I am uploading the ABAQUS input deck.
Please can anyone advise?
Chris
Is this ok?
That is,
*CLOAD
*CLOAD
*CLOAD
*CLOAD, OP=MOD
*CLOAD, OP=MOD
That is:
Chris
RE: Bolt pre-load
