Tolerance Setting or Adjustment to Recognize a Sheet Metal Punch Outline for Auto-Tooling
First of all, I apolgize if this is the wrong place to post this message. If it is, please advise otherwise. I am a mechanical designer by trade but I have been forced into solving this particular problem.
I have a SolidWorks (2012) sheet metal part (doulble break panel) that has several sets of numbers on it for panel identification. The numbers are created as features and as sketches using a font that I created. Basically, the font is nothing more than rectangles arranged vertically and horizontally to represent numbers. Once a part is complete, a DXF is generated of the flat pattern, for manufacturing. Up to this point, everything is okay.
The problem occurs after importing the DXF file where the rectangles are supposed to auto-tool in the CAM software. Manufacturing uses an old Amada Press with AP100 (US) Software (Version 7.0 MetalSoft Corp.) The "auto-tool" process works on some of the rectangles but fails on others. The difference between success and failure to auto-tool is a descrepancy of tens of thousands of an inch (.00014).
Example:
Rectangle tool; .375 x .063. DXF imports some rectangles as .37511 x .06357 and others as .37528 x .06372 because of the difference in numbers, only some of the rectangles auto-tool.
Is there a solution to this problem?
Any help would be greatly appreciated,
Best regards,
Eddie
Example:
Best regards,
Eddie
RE: Tolerance Setting or Adjustment to Recognize a Sheet Metal Punch Outline for Auto-Tooling
B.E.
I know I can edit the file but the whole purpose of auto-tooling is to eliminate un-necessary steps and streamline the process.
Thanks for te response.
Eddie
Are the rectangles being "scaled" by Metalsoft during dxf input?
Figure out which one and contact that company to discuss why and what your options are.
NO idea why you have a font entered at .846" to get .375"??
If the actual font height is incorrect in solidworks its going to be incorrect in the dxf file..
I'd suspect if you adjust the number of units your measure tool in swx shows you might see the problem right there..
I'd suspect you need to go to more than 3 digits when inserting your font so its "more accurate" to start with.
