ABAQUS - User Subroutines on Windows 7 and on a cluster computer
I'd like to know if I'm able to take advantage of user subroutines on the following two platforms:
-Windows 7 - I understand you need a FORTRAN compilier, but must it be Intel's pricy one? There are others out there, but they seem to require you to have pseudo-linux environment and I'm not sure how well Abaqus would play with this.
-Cluster Computer (linux environment) - is it any easier when submitting .inp files on the command line?
Thanks in advance for any help.
RE: ABAQUS - User Subroutines on Windows 7 and on a cluster computer
There are binaries for windows, so i guess installing is not an issue.
Change your abaqus .env file to work with gfortran (search this site how to, A LOT of people have asked this before)
I don't understand your second question. Your cluster probably works with a scheduler of some sort, ask the guy in charge.
