Bridge in Washington State collapses
5
RE: Bridge in Washington State collapses
KIRO news from Seattle just had a Washington DOT representative state an over height vehicle struck the bridge and caused it to collapse. Well see if that story hold up.
any preliminary views as to what caused the collapse? span looks to have been simply supported. i'm not a bridge engineer but is that the norm for multi span bridges these days?
no fatalities it seems thankfully
Initial speculation is an overheight vehicle hitting the upper portion of the bridge. This was an older bridge with laess than optimal clearance for today's traffic. We'll see.
I also noticed some plants growing at the river pier by the rocker supports - not a good sign of proper maintenance in my opinion.
Mike McCann
MMC Engineering
Apparently an oversized load truck was heading southbound in the slow llane instead of the lane to the left where the clearance was greater, and hit one or more of the curved crossmembers above. The collapse followed VERY soon after that, apparently.
Mike McCann
MMC Engineering
thanks mike. looking at photos of the bridge it appears that the curved cross members are present on all of the spans. if so, i wonder did the driver move across to the middle land after crossing the first span or are the other spans in danger of collapse for the same reason?
Don't know yet...
Mike McCann
MMC Engineering
Buckled top chord compression member? It's hard to believe that a truck with an oversized load could hit the top (diaphragm) truss and buckle the whole thing. But there she lies in the water.
Facts:
1. Steel Warren truss with verticals, with steel and concrete deck structure, designed 1954 and constructed 1955.
2. Four 120' spans between concrete piers and abutments.
3. North 120'span failed.
4. Semi was hauling an oversized load and being proceeded with an escort vehicle used to verify the clearance height available.
5. Semi was traveling in the wrong lane - the slow lane, where the clearance was less.
6. The bridge had no height restriction signs posted.
7. In the State of Washington, for oversized loads, it is the responsibility of the transport company to get a state permit and verify all clearances along their proposed route.
Don't know of a Bailey bridge triple-triple will work for this span, but with load restrictions and special applications, it might work on a temporary basis, at least for emergency vehicles - the state does have a stockpile of BB parts.
Bridgebuster: Were you driving the semi? rofl
Seems like this is the perfect example of what results from a lack of redundancy, unless there is more to the problem than meets the eye here, which is very, very possible. Being such a critical bridge for commerce in the area, and since it is of older construction, designed and built in the early days of the Interstate Highway system under Eisenhower, it would have been prudent, if the bridge was not going to be updated, to do one or the other of the following two things:
1. Post the height restriction in an bodaceously visible spot, and/or
2. Construct a steel or concrete overhead warning barrier for over the height limit vehicles so that they are damaged and not the bridge. This could have been so easily prevented.
Too bad it's too late now. $15 million to replace at a minimum, and guess who pays for it....
Mike McCann
MMC Engineering
Height barriers? But you have so many more important things to deal with in WA...legal pot, gay marriage, etc.
Yea, and Ron told me that you were planning to relocate after you heard the news Hokie!
Mike McCann
MMC Engineering
15 million?
I'm not sure you could even get the enviro permits and the drawings for a government design decision nowadays for 15 million.
250 million minimum. Full rebuild and disposal of the old (laed-painted) steel and water/dredging/enviro permits for disposal of the submerged steel and new waterway dredging? 800 million more likely. Union state ya know.
Mike - I innocent (this time, stuck n traffic on I280 in New Jersey
I hit the send button by accident woofer correcting my errors. I reiterate my innocence.
I did it again.
I read an article where the State of Washington rates the bridges on a 0-100 scale (0 being the worst), and that any below 50 are slated for demolition... the collapsed bridge rated 47... so, just hastened the replacement...
Dik
I just passed over the Snohomish River Bridge on Highway 9 here, and it was posted at both ends at 14'8" in bright yellow signs. This bridge is of similar design and vintage and 0 to 100 rating - in the low 50's too I believe.
I just cannot fathom why this bridge, on a state highway, and of a higher clearance, is posted, but the interstate bridge over the Skagit River, a lower clearance, was not.
The only thing I can figure is that the State and Federal regs are not the same regarding posting of clearances.
Oh and the 15 million was the figure the Governor mentioned, and only for a replacement of the section that collapsed, not a complete replacement.
Anyone found where Mr. Bailey lives yet?
Bridgebuster: How much did you pay to have this done? :)
Mike McCann
MMC Engineering
Mike - I should have done it a few years earlier when the exchange rate was about $0.75 rather than the current $0.97. Anyway, I'll make it up in my fee. Funny thing, I just happen to have a set of plans for a bridge that size. winky smile
from the Winnipeg Free Press:
SEATTLE - The chairman of the National Transportation Safety Board said Saturday the bridge collapse in Washington state is a wake-up call for the nation.
"This is a really significant event and we need to learn from it, not just in Washington but around the country," Debbie Hersman said after taking a boat ride on the Skagit River below the dramatic scene where a truck bumped against the steel framework, collapsing the bridge and sending two vehicles and three people falling into the chilly water.
Investigators need to find out what happened in Washington and if it could be repeated at similar bridges around the country, Hersman said.
Was a bridge inspection conducted after the oversized vehicle hit the bridge? It would not be hard to buckle these bridge members and Washington DOT would have been called by the police for an inspection.
As a correction to my earlier post, the clearance of the Skagit River bride was 15'6" and the truck oversized height was 15'9". So this bridge has more clearance than the Snohomish River Bridge.
And yes, I agree with the NTSB that this design could be a major flaw in the Interstate Highway System, a trigger just waiting to be pulled. Moreover, how much weakening to the structure had been done with earlier hits? The one that I am aware of was on the south side of the bridge, not the north, but I imagine there were many others, some documented, some not. The "straw that broke the camel's back" scenario here could be playing out too.
Mike McCann
MMC Engineering
I just read a similar article to what dik posted, and it says further that:
"State officials approved Mullen Trucking in Alberta to carry a load as high as 15 feet, 9 inches, according to the permit released by the state. However, the southbound vertical clearance on the Skagit River bridge is as little as 14 feet, 5 inches, state records show. That lowest clearance is outside of the bridge's vehicle traveling lanes, Transportation Department communications director Lars Erickson said Friday. The bridge's curved overhead girders are higher in the center of the bridge but sweep lower toward a driver's right side.
The bridge has a maximum clearance of about 17 feet, but there is no signage to indicate how to safely navigate the bridge with a tall load.
At a news conference later Saturday, Hersman said Washington state does not require signage unless the clearance is 14 feet, 4 inches or less.
The permit specifically describes the route the truck would take, though it includes a qualification that the state "Does Not Guarantee Height Clearance.
So, I am not really sure what the height clearance is or was as I have heard many different values here. In my opinion, but what do I know, what should be posted, or recorded. is the minimum height to the underside of the superstructure in the traveled roadway, whatever that was. The trucker must have moved to the left after he hit the initial portion of the bridge, as none of the other curved members, that all appear to be of the same geometry as the first from a Google Maps roadway view, appear to have been hit. Time will tell...
Mike McCann
MMC Engineering
chicopee - the collapse happened almost instantaneously after the collision. The truck driver reported looked in his side mirrors to see the bridge collapse immediately after he left the bridge.
The msn.com article which M^2 referenced earlier talks about previous damage to this bridge. Apparently it was inspected 6 months ago for high load strikes...it didn't say whether repairs were completed.
Murphy knocked it down, Bailey puts it back.
...which is where it should go in my opinion.
Mike McCann
MMC Engineering
I think I am going to sell ferry tickets online. :)
Mike McCann
MMC Engineering
A humourous reply from a Winnipeg Free Press reader, "Doesn't anyone see the plants growing on the tops of the concrete pillars???? Right where the steel bridge rests? I think we all know that plants cause moisture and moisture causes RUST! Therefore, the bridge rusted and collapsed and it hit the semi-truck. The semi did not hit the bridge!!"
Dik
Mike... it's legal in Washington!
Dik
“Fracture critical bridges,” b.s...., those talking and writing heads don’t have the vaguest idea what they are talking about, but using big words and phrases impresses the reader/listener. They are parroting something they have heard with little to no knowledge of the facts of the matter. I must confess, I’ve not seen either of these bridges, and didn’t witness the accidents either. But, I’ve inspected a few bridges after the fact, and been involved in HW&H shipments by truck and rail over the years. I am not trying to downplay the importance of redundancy in structures or the fracture critical nature of some structures. But, we have never designed highway bridges to have primary structural members hit/impacted/ripped out by a 30-40 ton tractor-trailer with a high load and not be seriously, maybe critically damaged. And, we don’t design multi-track railroad underpass bridges to withstand the impact of a fast moving train, or the derailment and collision of two trains, right under the bridge, and not be seriously damaged, maybe moving a pier top a few inches. If we don’t have enough money now to manage, maintain and renew our bridge infrastructure, just wait until we start designing and building for these slim possibilities; we won’t have enough material or money for one bridge.
The likelihood of the collision/derailment right under a highway bridge, as happened in MO, is really pretty slim when you consider ton/miles or track miles of railroad transport activity. This isn’t something we can practically or economically design against, we can’t afford to do that. We haul HW&H (high, wide and heavy) loads over the highways every day. It takes some clearance, structure load cap’y, and actual movement planning and study to do it right. Not just a car with blinking lights in front of the truck. Railroads and highway depts. have people who do this on a regular basis. If the state gave the trucking company a permit for 15.75', they would normally give some advice about critical clearance locations below that elev., but with no guarantees. That trucker should have had a route/trip plan which said stay in the middle lane at the Skagit River bridge, 17' clr. for a 15.75' load, is no biggy, and he should not have been going 40-60mph crossing the bridge either. That wasn’t even a particularly high or heavy load, was it? Someplace, I thought I saw a video, maybe only a recreation, showing the truck hitting the bridge, and continuing on, and the bridge falling seconds later. It seems that we would be wise to let these things develop a bit, before we pass final judgement. As knowledgeable engineers, we might do what we can to prevent (or correct) the talking heads from pushing the negative and spectacular for the sake of air time. And, we should use a bit of common sense about how we approach and analyze these situations, to help minimize the hysteria. And, I certainly don’t mean to downplay our need for infrastructure spending. ASCE has been harping on this for years to essentially no avail. But, we may need more spending on bridges, sewers and water mains, etc., not very glamorous, but essential to our economy and well being, and less on new stadiums and the like.
Makes one of those yellow PVC pipes that hang from chains at the entryway of most parking garages seem really cheap... And I have seen those before bridges and tunnels before.
JAE, I think your photo makes it clear. We should just be happy it wasn't a yellow egg-shooter-downer type of bird...could have been more catastrophic.
"We shape our buildings, thereafter they shape us." -WSC
dhengr,
One quick point: of course ASCE is going to rate our infrastructure deficient; they are hardly a disinterested third party, it is in their interests to do so. That doesn't mean it couldn't be the case, but, rather, simply that they are not in a position to objectively grade such a thing. It's no different than an insurance salesman telling you you need additional insurance or a shoe salesman telling you you need new shoes. Or, to state it in the inverse, it would be akin to a fox rating the hen house security system overdone.
As for the fracture-critical issue, my understanding is that that was brought up by Berkeley professor Abolhassan Astaneh. Per his post on another site he described how this issue was brought up in the mid-1800's and at that time they decided to recommend that bridges be designed using pure trusses, which are statically determinate, but which therefore have no redundancy. This is what he referred to as fracture-critical. According to him the decision was made at that time so that the structure could be properly analyzed and it therefore be known whether the chords were in tension or compression -- and to what degree -- so that they could be properly designed. His argument is that since we now have modern computer techniques this no longer applies and the structures should be designed with some degree of redundancy. I guess that's analogous to the movement towards progressive collapse resistant designs. That is my understanding, at least, and any mistake in conveying his views in this paragraph are mine, not his.
You can sure tell that was photo shopped. All those animals are from Iowa!
Mike McCann
MMC Engineering
Well, I guess that the Bailey Bridge is in the process of being assembled by a contractor as I post and will be rolled in place mid month. Looks like it's two levels deep, but I can't tell now many layers wide from the rendering.
Mike McCann
MMC Engineering
