HTHA in Carbon Steel
I have the task of examining possible HTHA damage in aged carbon steel pipe removed from service. Little if any damage is suspected. The method is optical metallography.
I am looking for some experience and recommendations for a metallography protocol. How are welds and HAZs affected compared to base metals? At this point I plan to examined it unetched and then etched, at magnifications ranging from low to as high as possible.
I have reviewed API RP941 and RP571; the latter mentions surface decarburization. Given that many steels start service with surfaces already decarburized at the mill, how reliable is this?
"If you don't have time to do the job right the first time, when are you going to find time to repair it?"
RE: HTHA in Carbon Steel
Don't know where we would all be without you, metengr.
I found it on the internet.
It may not address your question, but the bibliography is a great resource of its own on this subject.
Plymouth Tube
I was unable to locate a version that did not request a large number of British pounds. Any hints?
