Is there a way to Lock Mate 10 Parts to a single part?
Rather than use the mate function 10 separate times, is there a way to maybe select 10 Parts and use one function to lock it to the one base plate?
SW2013,SP3 HP Z400 Workstation
Intel xeon w3580@3.33GHz,Win7 PRO 64bit
Quatro FX1800
RE: Is there a way to Lock Mate 10 Parts to a single part?
Chris
SolidWorks 11
ctopher's home
SolidWorks Legion
Quatro FX1800
Once finished and everything is where it needs to be, you can dissolve the sub-assy and fix the individual components in their positions.
Open the Mate Manager
Switch to Multiple Mate Mode
Select the Lock mate option
Select the fixed part in the first field, and the parts to be locked in the second field
Click the green check mark
