Flying hovercraft
Flying hovercraft
So Ive decided to build one of these from scratch to pass the summer.
Im slap bang in the middle of 3 great lakes here in Ireland so Im thinking its time to bring to next level and go airborne.
Have done the sailing/speedboat deal so its the next 'sensible' step.
They are nothing new of course, Ill be running mine with an 2.0l n/a Subaru boxer engine. Everything else is kind of still in my head, but how hard can it be.
http://www.youtube.com/watch?v=qqxygnJIQVo
This place appears to sell them built, and in kit form - built they are 179,000 dollars (what?)
http://www.hovercraft.com/content/index.php?main_p...
Cobble together kit form, prices are still a bit 'what'
Have all skills to pull it off solo so I intend to enjoy it,
Anyone ever piloted one?
Brian,
Brian,
RE: Flying hovercraft
Well, Moller's been trying to make one for about 25 yrs..
TTFN
Don't forget to consider stability/control issues when 'flying'.
Plus, does your local jurisdiction post any limitations etc. - are you effectively in homebuilt aircraft territory?
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
No license needed as it only goes 5-10ft high,
Brian,
http://moller.com/dev/index.php/neuera/neuera-tech...
or
http://moller.com/dev/index.php/sky-car/m400-specs
TTFN
At least with hovercraft, Im sure I can get into the air with it. And if not, just add more hp and play with levers some more,
Brian,
Thats something I wondered about. The lakes here are pretty safe, as in ok water temps, my testing lake is probably 10ft deep average, but 'dig in' worries me a bit - and getting thrown from seat/overturn it etc.
I think/have seen the main danger is when hovering sizeways or washing sideways on a turn, craft rolls, and digs in, turning it over.
I have no idea how they feel to pilot, but I guess Ill just take it real easy. Much of my 'driving' will be straight line only, with no rocks, and sandy shores to run up onto.
Just trying to source foam for hull/bed now, It will be mainly hotwire cut, with some fettling. Over that, ply/glass and so on.
Brian,
I have been studying the Moller Skycar. It is fascinating. According the the website, the Moller Skycar weighs around 2500lb and it flies at around 300mph, getting 20mpg in the process. It has a total of 700hp. A Robinson R44 has a loaded weight of around 2500lb. It is a vertical take-off machine with 245hp, and a top speed of 150mph. A Rutan Boomerang weighs 4200lb maximum, it does 311mph on 410hp, and I would crudely guess the wing's lift to drag ratio to be around 15:1.
P=FV
Boomerang Thrust...
Fb=P/V
Fb=(410hp × 550 ft.lb/sec.hp)/(311miles/hr×5280ft/mile×1/3600hr/sec)=495lb.
Wing drag: Dw=4200lb/15 = 270lb.
This means that a Rutan Boomerang requires 500lb thrust to maintain speed, 270lb of which is used up by the wings.
The Moller Skycar has a fuselage approximately the same size, flying at approximately the same speed, so it should require around 250lb thrust. It weighs 2500lb. It is propelled and lifted by ducted fans, so the required thrust vector should be arctan(10), about 84° down.
In animated views of it flying, the ducted fans always are pointed directly to the rear. By my estimate, this configuration would happen at fairly high supersonic speed. Helicopters fly with their rotors fairly to close to horizontal.
If you look at the hovering Skycars on YouTube, you will see a crane in the background.
Perhaps I am doing something wrong here. I am not an aerospace engineer. I would be glad to be corrected.
JHG
Mike Halloran
Pembroke Pines, FL, USA
Couldn't be any worse than being upside down in a rally car while in a river so narrow you cant open doors...
Brian,
I recall doing wind tunnel testing of a scale model back in the 90's, but I dont remember any details of the resukts. It was one of my most fun jobs ever. We played racquetball on a court next to the dyno cell every night.
Do the fans thrust in the direction they are pointed, or is there some additional ducting? Note how the thing moves in the direction of thrust. It appears to be swinging.
I have Flight Gear installed on my home computer, and I have a model of the Skycar. I don't know who created it or if there is any connection with Moller. It shows vanes at the rear of the ducted fans, which might be doing something.
JHG
Have you thought of visiting the factory or test-flying one of them? Just to confirm that you get a good "feeling" piloting one. If it turns out you get the willies, well it would be better to find out before building one!
STF
Build nicely underway now, thrust duct almost complete, hull parts in the vac bag. Been eying up Subaru foresters as theres a few about for sale with failed Ncts(MOT) due to worn components - makes no sense to repair as they are worth nothing, so thats going to be my donor. They can be had for 400euro
Looks like Ill have to do the main prop in two 'go's on the cnc as my x travel is a little short, but thats do'able too.
Been toying with the idea of making the lift fan hydraulic driven to cut out mile long belts, but I have to brush up on my hydraulics a bit, its been years since I laid out a system.
Brian,
One thing I like about the hovercraft is that there is no wake(much), and none at all when in the air - until you crash that is,
Brian,
Brian, Are you talking about the kind of wake that takes 3 days?
Damn you got me good there, had a right laugh!
Mike, Im not sure the fuel tank is large enough to make it that far...
Ill be interested to see how high it can go when Im 'confident', I dont think I'll ever be fully prepared for what may happen though.
Brian,
