Preconditioning Hadfield steel by shotblasting
Has anyone had any experience in surface preconditioning of Hadfield steels thru shotblasting?
RE: Preconditioning Hadfield steel by shotblasting
There are special shop peen and hammering processes used.
Plymouth Tube
http://en.wikipedia.org/wiki/Ultrasonic_impact_tre...
http://fsel.engr.utexas.edu/publications/detail.cf...
Why did you select Hadfield steel ?
Hadn't thought of it. These parts are prototypes and even in production will be pretty low quantities. NiHard appears to be a casting alloy only, can it be purchased in bar stock and machined? Casting just a few will be really expensive.
I have worked with Hadfield in the past, I guess I was falling back on what I knew.
If the parts are a cylinder then casting shouldn't be a big deal.
You might look at explosive hardening if you need to do an ID surface. It works well.
Plymouth Tube
