ER316L VS ER304L
ER316L VS ER304L
Hy all
Q :I have a P8-P8 PQR produced on a SA 312-304L-304L base material with a ER308L filler wire.
I want to qualify a WPS of 316L-316L with ER316L F no,A no and SFA no are all the same.
Do I need to requalify my PQR in this instance or can i use the same PQR....
Tman
Tman
RE: ER316L VS ER304L
Can u elaborate more
First determine whether or not impact testing of the weld is required by the applicable construction code. If it is required, and assuming you're working to ASME Sec IX, review the applicable paragraph for the process under consideration. Eg for GTAW look at QW 404.12.
