journal to update for external change command?
I was wondering if there was a journal command to update for external change.
RE: journal to update for external change command?
The Session object has some update methods that might do it.
www.nxjournaling.com
Are you doing this simply because you want to avoid having to navigate to the function via the...
Tools -> Update -> Update for External Change
...menu sequence?
If so, perhaps you were unaware that you can use Customize and assign any menu item to an icon on a toolbar so that you can execute the function with a single gesture.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I am also looking for the same kindly help.
Dear Experts
Kindly give any suggestion for it.
Jayesh
