HOW TO CREATE FLUID VOLUME FOR THIS MODEL
While the solid mesh for a design part occupies the part itself, the fluid mesh occupies the void between the bodies.
Because the void itself is not a body, I must create a solid body to occupy the void.
If i import a model like the one attached, how can i create that solid volume with NX NASTRAN FLOW?
http://files.engineering.com/getfile.aspx?folder=a...
http://files.engineering.com/getfile.aspx?folder=b...
THANKS FOR YOUR HELP
