Longitudinal Weld Joint Quality Factor E
What is Longitudinal Weld Joint Quality Factor E
Why it is used in thickness calculation.
..recently i have seen in critical cases for all welded pipes we can use E=1...but how..ASME standard doesn't says E=1 for all welded pipes..
please find the attachment.
Please clarify and give detail description that we can use E=1 for all welded pipes.
