what is a ''test club'' prop/ prop control required for bench run of turboprops engines
I recently cam across test bench run requirements of t501, commercial equivalent of a famous t56 engine... it had mandated use of 'test club' prop and prop control for bench run of any engine used onto it....
further this 'test club' parts were also not to be used on aircrafts
to me it was strange.. if any body can explain......
RE: what is a ''test club'' prop/ prop control required for bench run of turboprops engines
B.E.
Quando Omni Flunkus Moritati
