Braking with radial piston motors
Hi guys, got what is probably a simple question for you.
Radial piston motors
Closed loop drive system.
Hydraulic brakes
PM is an electric motor which is on/off as you use the machine.
The issue as you can imagine is when driven up a slope and the motor is stopped, the radial piston motors do not like this. Not to worry, we have the main brakes to hold the machine steady. When we come to set off again, as the brakes release, we roll back a foot before sufficient pressure has built up to hold the motors steady again.
An expensive way around this might be pressure sensors on either side of the pumps closed loop and when we reach a certain pressure, then the brakes release but are there any other common solutions to this problem?
Hydraulic brakes
RE: Braking with radial piston motors
Initially it was just electronic and only the charge pump pressure in the system holding the machine which wasn't enough on any slope.
John P.
Mocked up in a simulator this does work. Sometimes I get strange oscillations but that might just be fine tuning in the simulator rather than it going to be an actual issue.
Main drive loop > shuttle valve A-B > Pressure reducing valve > POV normally dump to tank > Electronic controlled diverter normally dump to tank > Pressure relief valve > Brake release.
The reason for the PRV before the brakes is there is another method of brake disengagement which cannot be put in before the reducing valve.
Lyle
As I mentioned it was a while ago and I did not complete the detailed engineering (I had a Subcontractor complete the detailed design and eventually this functionality requirement was dropped).
It may be worth calling your local trusted supplier and see what, if anything, they can do for you.
Lyle
When I drive up a slope and let go of the controls, everything is fine. I can press the trigger now but when I try and drive forwards, the 35bar needed to release the brakes is not enough to hold the machine steady, at least, not until it has rolled back a bit. I can hear the pistons slapping until enough pressure has built up again in the drive loop.
I am not sure how I can get around this as the drive pressures might only be 40-50bar on the flat but on a slope, 50bar is not enough to hold the machine steady. The slopes I am testing on are 30%+ which are pretty steep and the machine weighs in excess of 3 tons.
I presume your pilot operated valve (sequence valve?) is looking for a least 35 bar in the high pressure leg of the closed circuit before the brake will release. If you raise this setting for a successful hill start on the steepest slope you probably find this setting is too much when starting out on the flat.
I’ve got a nasty feeling that you are going to have to resort to some electronics. Have you considered fitting a tilt sensor (inclinometer) to the machine? The output signal of this can be used to increase the setting of a small proportional relief valve fitted to the drain line of your sequence valve. When the hill is steep the inclinometer output signal will be high, the relief valve setting will be high and the sequence valve setting will also be high – meaning the motor drive pressure has to be that much higher before the brake will release.
Actually you might need two sequence valve systems – one in each leg of the circuit. This would accommodate all four drive scenarios: driving forward uphill, reversing uphill, driving forward downhill and reversing downhill. Alternatively if you can identify the intended direction of movement you could get away with just one valve assembly and a whole bunch of logic controls.
DOL
I am looking at motion control valves on closed loop systems but it seems generally accepted that this is not a good idea. The oil in the loop gets very hot and we lose a chunk of efficiency we have been working hard to get.
Surely radial piston motors have been used on a machine before with an electric motor as the prime mover without tilt sensing and proportional brake valves.
Ted
When you say I need a flow blocking feature that causes the flow out of the pump to rise above drive pressure, this is not much use as drive pressure on the flat could be 50bar, on a slope it could be 180bar. The variation is the problem.
This is only really possible with proportional electronics.
Ted
Metering flow from a higher pressure is not possible, this is a closed loop system.
Ted
When you are driving your car you know when to use the hill start technique - it's when you've parked on a hill. You recognise the presence of the hill and remember to do a slightly different thing to the normal start. So how about putting in a small push-button that the operator can press when doing they recognise the need to do a "hill start". The action of the button would be to interrupt the signal to the brake solenoid so the brakes didn't actually release. Then when they have held the joystick handle over far enough and long enough to feel the machine trying to drive up the hill they could let go of the button - the brakes would release and up the hill they go. A simple control, will by definition be less sophisticated than a more complicated control ... but it works on your car so it might work on this machine.
DOL
Whilst the idea of a separate control for hill starts would probably work, it is not ideal. It is starting to look like this combination of pump and motors and control system doesn't go together very well as a mobile hydraulic drive system.
I did some pressure tests yesterday and found that when recording A&B on the pump, I could see from a starting on the slope, I would first see the charge pressure over the whole loop, I would then see "A" rise quite sharply, and "B" would lower to 0 bar temporarily as the machine rolls back and kind of reverse cavitates until the pressure builds enough for it to hold the machine.
@hydtools
Yes I understand that but a shuttle valve over A&B picks the highest pressure and it only needs 35 bar to begin opening the brakes. If I had a PLC I could put pressure sensors and feedback response on the joystick to work out what is going on and pick the appropriate action but this is almost entirely hydraulic.
As soon as the A pressure reaches 35 bar that’s enough to release the brakes – but not enough to hold the vehicle on the slope. The radial piston motors run backwards (acting as pumps) and they take the oil out of the B side and push it into the A side. To recap: just at this instant in time the pump is pushing oil into A (and sucking out of B) and the motors are pushing oil into A (and sucking out of B). The only thing pushing oil into B will be your boost pump – and if the B pressure is dropping to zero then the boost pump is not keeping up with the flow demand.
So your boost pressure is dropping to zero –the pump won’t like that one little bit. The pump will start to cavitate and the flow you were expecting it to deliver isn’t going to be there. This might also be contributing to the noise. The motors (running backwards and acting like pumps) will also be cavitating – and they won’t like that either (more noise).
Here’s a funny thing to think on as well… if the motors do more than one revolution while they are running backwards (eccentric crank type motors – Staffa, Calzoni etc.) or if the pistons in the motor do more than one stroke (external cam type motors – Poclain, Hagglunds etc.) then the cavitation means that the piston chambers are not being refilled properly on their “suction” strokes. If the chambers are not completely full then the pistons provide no resistance to the rotation of the shaft when they are on their “delivery” strokes. The motors freewheel [noisily] and this will exacerbate the roll back.
You might want to try fitting a small accumulator to the boost pump outlet (and a check valve to stop the accumulator back driving through the boost pump). The accumulator will help to support your boost pressure during the transient conditions of a “hill start”.
DOL
Lyle
Lyle
I have attached a pressure log showing the pressure drop on the "B" side. The higher pressure is on the "A" side being squeezed by the wheel motors and the pump.
Our engineers can control and tune systems over the internet using gotomeeting or gotoassist and configure and tune systems anywhere there is an Ethernet connection. Resistance is unprofitable.
Peter Nachtwey
Delta Computer Systems
http://www.deltamotion.com
We managed to make the issue a lot better by bringing the pressure reducing valve down so the pressure is enough to release the brakes but no oil is wasted stroking the brake cylinder further. The capacity of the brake cylinders was relatively large before, but now it seems a lot better. It also helps slow down the brake disengagement which gives the loop time to maintain pressure.
