Any smart way to feed New Assy with existing Sub-Assy references to Enterprises PDM
Greetings...!
SolidWorks 2011, SP 5.0
I have copied an existing Top Level Assembly into a new Assy name from Enterprises PDM and replaced some of the sub Assys and Parts in the Local Drive . There are some more existing sub Assys already assembled in this new Assy. Now , I have put this new Assy to the Enterprises PDM. If I try open the new Assy, I am getting error message for the Existing Sub-Assys like "Unable to locate the Existing subAssys those are reporting to New Top level Assy. Do you want to find yourself?"
Can anyone pls find a solution to fix this issue?
Is there any smart way to feed New Assy with existing Sub-Assy references to Enterprises PDM?
Thanks for the help...!
-M
RE: Any smart way to feed New Assy with existing Sub-Assy references to Enterprises PDM
This may help.Link
