Teamcenter. Where is a part used with Impact Analysis
I have updated a hydraulic cylinder. And now i want to know where that cylinder is used to check if all the assembly's where that cylinder is used are still ok.
There for i use Teamcenter Impact Analysis.
That shows a list of all the assembly's where my cylinder is used. So far so good.
But my problem is that the list that is shown is not sorted. It shows all assembly's with all the previous versions of all those assembly's totally random.
Is there a way to sort that list in numeric/alphabetic order? And even better would be when it only shows only the latest revision of all the assembly's.
I hope someone has a answer for me.
Thanks already.
Using NX 8.0 on Windows 7 (64)
RE: Teamcenter. Where is a part used with Impact Analysis
Can you not change the Rule filter to show only latest revisions?
Thank you for your answer.
I've tried all the rules. But not the desired result.
And the rule "Latest Revision" does not exist in the list.
You may need to get a site admin to add in that rule/load option.
We currently only use: All, Latest working and Latest released state as load options.
A few weeks ago i've had a 4-day cours of Teamcenter admin. And i have admin rights.
But i have to search and puzzle where i can ad "Latest Revision".
