offshore NUI lighting
In an offshore normally unmanned installation is it mandatory to provide a task lighting and escape lighting or is it ok to provide only escape lighting.
Any code reference for the above will be appreciated.
regards
regards
RE: offshore NUI lighting
Best regards
Preben
Thanks Preben
also API RP 14 F states the same about the lighting. however as you have indicated that in north sea that there is a practice of installing only the service light. does that imply that there is no mandatory requirements for lighting for NUI ?
regards
