Output question
Output question
I have a small question on outputs such as E11,E22,E33,S11,S22,S33,U1,U2,U3 etc. Lets say I have use an orthotropic material and have defined the different material orientations. The outputs I mentioned earlier, are they based on the global coordinate system or the local coordinate system that I used to define the material orientation? Is there a way to get the outputs based on global and local at the same time? These are the questions that I would really need an answer too. Hope someone could help me with this. Thanks in advance.
RE: Output question
Yes.
Search "local coordinate system" in the CAE User's Manual. CAE lets you carry out the transformation.
Are you new to this forum? If so, please read these FAQ:
http://www.eng-tips.com/faqs.cfm?fid=376
http://www.eng-tips.com/faqs.cfm?fid=1083
RE: Output question
RE: Output question
RE: Output question
