piping material for seawater service
What are the restrictions on using plastic pipes (pvc or PE) for seawater underground pipes instead of using carbon steel internally painted and externally insulated in addition to cathodic protection???
RE: piping material for seawater service
Gve us a bit more of your intended use (flow rate, size, pressure, depth etc) and you may get more info
