Angle measurement in Catia
Hi everybody
In catia, is it possible to measure angles and get negative values for this measurement? "measure between" tool always gives positive values for angles.
RE: Angle measurement in Catia
Why? do you need it? you could use knowledgeware get the wanted behavior
I need to plot the values of a series of angles during simulating a mechanism in Catia and the direction is really important for me
what is knowledgewarw, I have not worked with it yet
I would try to set up a parameter of angle type and control it with a rule, if the alfa exceeds 90deg the 180-alfa*-1
I have solved my problem using your comment
Knowledgeware is the solution
Now I can plot steak movement versus elevator rotation in my airplane model and the direction of angles are covered
GRAZIE
