GSD_points spline loft excel
Hi All
I am trying to create a spline through "GSD point spline from excel, Everything is fine But I don't see pints or spline in my Catia window. Why?
I am Using Catia V5R20, and Excel 2007.
Please Help me to come out this Issue.
RE: GSD_points spline loft excel
A screen capture ? Are the elements created or not?
Fernando
https://picasaweb.google.com/102257836106335725208
https://picasaweb.google.com/103462806772634246699...
My Excel data is reading, but in catia screen output is not comming.
thanks
and description of your process
do you strat with a new CATPart?
is there a geometrical set in your CATPart?
Yep I want start a new part. I don't know about Geometrical set. Please let me know how to set geometrical set.
Here I attached a screen shot and Points file.
Thanking you.
I don't remember if the attached file is modified comparing with what DS put it in the original docs, for me is working well in r18. Just run the main routine, put what ever option you want and see results.
The Excel file has to have exactly this kind of format.
Fernando
make sure X is in column A, Y in column B and Z in column C.
In your file it was all shifted 1 column to the left.
regards
