Outside Air Compressor Exhaust
All,
I have an air cooled air compressor located outside and I would like to know how the exhaust heat coming from the fan on top of the compressor is calculated. The manufacturer is telling me that the discharge flow from the fan can range from 15,000 to 20,000 cfm and it may contain as much as 1,000,000 BTU/hr. I am mainly concerned about the high heat capacity they are listing as there are some components located above the compressor and I would like to know what a safe distance will be to allow the heat to dissipate. If anyone has any insight as to how this can be determined please let me know. Also, if you think this should go in another forum please let me know.
Nick
Nick
RE: Outside Air Compressor Exhaust
Nick
