Basic Building Codes Question
I'm trying to get a better understanding of different building codes and when they are used. I started to write down a list of all the codes that apply to me locally and came up with the following. Basically, which codes supersede the others?
For example: Municipal code, CBC, Title 24, ASCE, ACI, etc.
RE: Basic Building Codes Question
http://www.iccsafe.org/gr/Pages/adoptions.aspx
In all these cases, the highest level code supersedes any code adopted by reference. For instance, the state amendments will supersede anything in the IBC. Changes mandated by the IBC will supersede the codes it incorporates, etc.
Brian C Potter, PE
http://simplesupports.wordpress.com
The code writing frequently comes from groups that consist of different individuals with varying backgrounds. Usually, a locality adopts a model code (IBC, IRC are the most common) that puts in to effect legally and can amend, but not reduce the minimum standards.
IRC, and IBC codes are written by those organizations connected with or are members of the ICCC. The codes are put into "code language" that can be enforceable. The codes also adopt and accept many items/standards
There are many other groups that write appropriate standards relation to appropriate products, testing and procedures, practices that are open to the public. These are usually comprised of an assortment of people with different interests.
I have been a member of ASTM for 20 years, and it took me 10 years to be a voting member on several committees. The reason for the time is because the committees are what is called a balanced "consensus" group consisting or manufacturers, users, and interested parties (little old ladies, professors, etc.). It is a one member per vote and no voting corporate members, but corporations are members to support the organization. It is not cheap and can be time-consuming to participate in standards considering the time, travel, hotels (2 multi-day meetings annually plus other communications) and other expenses necessary to be active, since if you do not participate, you could be dropped as a voting member. Obviously, nothing happens immediately, but it provides a well based, verifiable basis for codes.
I was lucky to start working for a concrete block manufacturer and I was required to be involved in any local or national organization association/group dealing with my area of engineering (structural/civil) despite the time involved, dues and travel/housing costs.
Dick
Engineer and international traveler interested in construction techniques, problems and proper design.
Thanks!
