NX 7.5 Part Configurations
Hello all. I used to be able to make different part configurations in SW which would suppress or unsuppress certain features in a part.
I have a part that will have tapped holes at the assembly level, but not as a component. In the past I would have two configurations of this part in the same part file i.e. "w/ holes" which has the hole features unsuppressed and "w/o holes" which has the holes suppressed. In assembly drawing it would show the "w/holes" in a particular view and may show the "w/o holes" in another view. These would be 2 different assembly "configurations".
How is this possible in NX? I would like there to be an arrangements function to be used with features for part files in addition to parts for assemblies. Since I can't add the holes at the assembly level without making the part a linked body (don't like to do this), how can this be accomplished?
Thank you,
Mike
Thank you,
Mike
RE: NX 7.5 Part Configurations
What you need is promotion. Insert > Associative copy > Promote body.
Try it. It's not the same as creating a linked body.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I only gave a hint than modification of a part geometry in the assembly context can be made without creating a WAVE-link.
