CATIA V5 R21 SP4, No Suitable License Error
Hi Everyone,
I'm getting an error when trying to load up a new version of CATIA that I have installed. It says:
"No License Available for Requested Configurations, Please choose at least 1..."
In another box it says:
"There is no suitable license to fulfill the request, License servers configuration file, file not found"
The list of licenses is greyed out, so I can't choose anything. Thank you for any help.
RE: CATIA V5 R21 SP4, No Suitable License Error
I'm guessing that you have a LUM license but from R21 the default license server is Dassaults own license server. If you have a DSLS license then you need to add hostname and port for the license server in a txt file named DSLicSrv (not sure if that is the correct naming) at the location mentioned in the error box. But if you use LUM license then you need to add the system variable DSLICENSING=LEGACY
