Bolt Pull Out from a plate (simply supported)
I am trying to figure out the maximum load I can apply on a bolt (3/8"-16 A325) in tension. The bolt is located at the center of 30" x 30" 1/4" thick simply supported steel plate. I do not care if the plate yields, as long as the bolt can take that load. What all failure mechanism should be considered for the this analysis ? Is only checking for the "bolt pull out" (shear strength*Pi*D*t) adequate for this analysis. What about the local yielding that occurs around the bolt hole. Does that local yielding reduces the bolt pull strength. How do I consider that effect in the analysis. (Since the roark's book only considers elastic analysis, using roark's forumla for concentrated load will be too conservative in this case).
Thanks alot for your help.
StrainStress
StrainStress
RE: Bolt Pull Out from a plate (simply supported)
Even if you are not concerned about yielding of the plate in question, the load on the bolt will cause a prying action that will act in combination with the shear at the bolt hole. AISC 360 covers this in Chapter J. Also remember that the root area of the bolt will limit the allowable bolt load due to the reduced cross sectional area.
