Combine Solid and Extracted Body
Hello !
My question is whether there is any way how to combine solid from extrude, and extracted body from sew of two pieces of closed sheet ?I try function "Unite" , but i can't select the body created by "extract geometry". Any ideas ?
RE: Combine Solid and Extracted Body
Could you provide at least a picture of the model, if not the model itself?
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
The body from extracted geometry is probably still a sheet body.
You cannot unite solid and sheet bodies.
Place the cursor on top of the body from extracted geometry, then wait for the quick-pick three dots to appear, then select and in the quick pick dialog scroll down to the bottom and note if it is a sheet or solid body.
When you sew sheets, if they are watertight within the tolerance and logically possible to convert into a solid, the result will become a solid body, else NX sews a sheet body.
Tomas
While it is true that you cannot join Solid and Sheet bodies using the normal Boolean -> Unite function, if the bodies are created so that they match/adjoin properly (which is why I wanted to see at least a picture of the model) they CAN be combined into a single Solid body using the 'Patch' function.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
And there's even a special situation where you might even be able to 'Sew' a Sheet body and a Solid body together.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
