Machine guards
Machine guards
Hi all,
Just wondering if anyone has made/designed these type of guards described below. I'm loking for the type that remains attached to the guard when removed. Is there a product that can be bought off the shelf to do this, haven't found anything on the net to date, i presume it would be some type of recessed bolt, you put this in the guard and maybe crimp something on to the recess of the bolt, thus holding the bolt to the guard. Presume this is all done somwhere already, must do this with stainless stell parts.
Hope i'm explaining this reasonably well.
Any advice would be greatly appreciated.
Best Regards
L
"The European Machinery Directive requires additional layers of safety. The Machinery Directive requires fastener systems to remain attached to the guards or to the machinery when the guards are removed, and, when possible, that the guards are incapable of remaining in place without their fasteners."
RE: Machine guards
http://www.southco.com/en-us/product/hierarchy.htm...
or here:
Hope that helps.
RE: Machine guards
McMaster.com stocks a fair assortment, including stainless.
Mike Halloran
Pembroke Pines, FL, USA
RE: Machine guards
Southco are certainly good products, and so are Savetix (www.savetix.de)
Whichever systems you are interested in, keep in mind that different clearances and factors go into ensuring your guards remain easily removable. Get some samples and install them into various examples to learn how they will/won't work as direct retrofits.
David
RE: Machine guards
RE: Machine guards
Thanks for the replies, got a lot of informtion here, www.savetix.de looks particularly useful, cheers geesamand.
L
RE: Machine guards
Plus simple captive screws are readily available places like McMaster etc.
What is Engineering anyway: FAQ1088-1484: In layman terms, what is "engineering"?
