Cutting deformable components in the assembly
Greetings all!
I discovered that it is not possible to perform Assembly Cut on the deformable component in the assembly. Neither it is possible to create WAVE link or promote a body of it. I'm effectively stuch not being able to subtract a material from a deformed component. Is it possible to do at all? Is there a workaround?
Note: this is a real task for the job, not a 'what if' scenario.
RE: Cutting deformable components in the assembly
Well, I can think of a workaround - creates certain features which would change geometry to a desirable shape and add them to the deformation feature, thus creating representatin of the necessary cut in the assembly. But is there some other way?
What you do is in the Assembly, perform a...
Insert -> Associative Copy -> Extract Geometry...
...and make a copy of the Solid body in the Deformed Component. Now Hide (NOT Suppress) the Deformed Feature and create the desired tool body(s) and subtract them from the associative copy of the Deformed Feature. Now you can still edit the 'Deformed Component' and the model will update as expected.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I tried to do exactly that. But NX doesn't allow me to extract solid body of a deformable component. I can only extract face.
What version of NX are you using? I had no problems doing this in NX 8.5.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Worked like a charm (see attached). You just need to be careful when selecting the bodies when you preform the Boolean subtract.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
John, I am totally at loss why does it not work for me. When I go insert > associative copy > extract geometry, I can NOT pick a solid body for extraction. What can be wrong?
When you're in the...
...dialog, make sure the 'Extract Geometry Type' is set to 'Body' and the selection filter is set to 'No Selection Filter' or 'Solid Body'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
But what can be the reason?
I can't explain it. I'm doing nothing special and we're both using the same part files so it's not a part problem. You may have to take this up with GTAC and have them look at your configuration.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Try resetting the dialog by clicking on the reset button at the top of the dialog:
Anthony Galante
Technical Resource Coordinator
NX5.0.6, NX6.0.5, NX7.5.0-> NX7.5.5 & NX8.0.0 -> NX8.0.3.4, NX8.5.0.23
Check if you have the latest mp's and mr's at first.
have same issue with NX 8.5.0.23. Have a feeling eex23 is right, a mr and mp update will fix this. Another work around Instance Geometry works with NX 8.5.0.23.
NX 8.0.3.4 mp2, TC 8.3
I have 8.5.1.3. Not sure if this is the latest thing - how to check this?
Note that I was running NX 8.5.2.3, the latest MR, which will be ready for customer download in about 3 weeks or so if all goes to plan.
To determine the exact version of NX that you're running, go to...
Help -> About NX
...and you will see the version designation at the top-left of the dialog window. To get even more information, hit the large 'button' labeled 'System Information'.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
Thanks for the info, John!
I know how to get the information about the version I am running. I do not know how to check if it is the latest! :)
If problem is lack of version NX 8.5.2.3, I will wait untill it is released and then get back to you with the results.
If you sign-up to receive SFB's (Software Field Bulletins) from the GTAC support site...
http://support.industrysoftware.automation.siemens...
...you'll automatically get notified when new software, both full releases and MR's, are ready to be downloaded.
John R. Baker, P.E.
Industry Sector
Cypress, CA
Siemens PLM:
UG/NX Museum:
I just tried it from scratch in 8.5.1.3, New parts.
same status as Printscaffold. No go.
But, i found a workaround.
Instance Geometry - Translate ( Any direction) distance=0, number of copies=1.
The result should be quite similar to what Extract geometry should produce.
Tomas
