"Nested" parts and no penetration
Sorry if this question is a little vague...
I've got a customer who wants to stiffen a long aluminum rectangular tube with a short length of smaller bit of steel channel centered within it. I thought I'd run a quick sim to just see how it behaves... And I'm having trouble setting up the correct boundary conditions such that the outer tube bends until it contacts the steel center as one would expect. They start off without contact, so I added a "no penetration" condition to them, and they just move as if bonded. I can only assume there's something to do with the "gap" feature, but being that I set that down to a few mils and the parts are separated internally by a hundred times that, I'm at a loss on how to make it behave.
Tweaking a few random options (like global non-penetration) and trying h-adaptive is making it run quite slowly.... Just looking for a quick pointer, thanks!
-Abe.
-Abe.
RE: "Nested" parts and no penetration
The global bonded condition (default) only works if the parts have initial contact so this shouldn't be the problem in your case.
If you manually add a no penetration contact (also works with bonded) the part don't have to have initial contact.
I was hoping with this to get an idea for when my central beam would overstress it's shell and break through. With this simulation I get none of that.
I have convinced myself that the times where the shapes flex independently and appear to go through one another is actually the scaled deformation - the beam may bend only 0.100", but it translates 0.400". When the deformed plot exaggerates this, the central beam "leaves" the envelope of the other part. That's a working theory. So far I can't figure out why sometimes they bend together and sometimes they move relative to each other.
This shows both my result (scales at 1x), the whole system (with a split line on the external face for fixtures), and a close up of how I defined the force and fixture. Everything's taken at a pretty steep angle since the aspect ratio (2%) won't allow a face on view with any detail on a reasonably sized image.
Right now my suspicions lean towards gap handling and bonding. In this case, I have no global bonding defined (suppressed) and I have the four inner faces of the outer tube as well as the 5 outer faces of the inner channel set up in a series of 1:1 (or 2:1 in the case of the open end of the C) 'no penetration' contact sets.
I'd truly love to get this working, especially since for my own edification we have a physical test rig set up and I would love to test the results. Thanks in advance for helping or any publicity you can give my problem.
As far as global settings go you want to use Allow Penetration and then specifically set your contact conditions between the parts. Also, this will have to be run as a non-linear analysis. Linear static analysis cannot do what you are trying to do. Let me know.
In real life, the beam is vertically (between windows in a tall building), and a bolt or otherwise will be slipped thought the outer channel to prevent the channel from falling. It really does "free float" in there as best as can be accomplished. I was thinking perhaps some weak spring or some such to better define it might be appropriate, but I really just want it to sit loose in there. I was thinking of bonding just the very ends of the bar to one side but I didn't want that force of compression showing up preventing the aluminum to stretch.
I can certainly add a global Allow Penetration condition.
As to the conditions I have defined - all inner surfaces (4) of the outer channel are "no penetration" with the closest outer surface of the inner channel (if you shook the whole assembly, that's what keeps the channel from popping out the sides). The only oddity is the open side of the channel (with it's two small ~0.135" faces, so for that relation I have the two of them "no penetration" with the inner wall of the alum channel facing it.
Let me know if that's still not clear, and if I'm mistaken about the non-linear sim not allowing "no penetration". I read it in help and didn't see the option in the software (2012)
This is just the basic model with two configurations for inner beam centered or resting against one wall. If you need more PM me your email and tell me what you need.
Thanks!!
-Abe.
P.S. On another deadline for tonight, tomorrow I will likely be able to experiment with non-linear again. Not sure why I didn't see no penetration before.
Attached is the same assembly, with the non-linear study files included.
In SW, contacts, large displacement and "in plane effects" (stress stiffening) are available in the static analysis.
I would try to add a fixture on one node on the inner structure and lock it only in the axial direction to prevent RBM.
Don't use the soft spring option.
I also prefer to manually add BC instead of the global one for "no penetration", but it should still work if you stay on global.
See if this helps.
I did a non-linear real quick and saw a difference in deformation between the two bars, so I feel I'm on the right track. That said, I like the idea of of the single bonded contact.
What's wrong with soft spring? You're right it seems I wouldn't need it if I had it bonded - otherwise it fails.
http://files.engineering.com/getfile.aspx?folder=8...
The real key is figuring out how to properly restrain the inner part and still observe the stiffening effects you are after.
Cheers
Perhaps try to download the files I attached earlier? There are a couple changes:
1) My beam is fixed on both ends, bending in the middle
2) My beams have some/more cross sectional thickness
The issue I'm having with what you posted is that it matches what I was getting earlier - a bar in the middle flexing for no reason. There's nothing really pushing on it. What I ultimately am after is what is the pressure/force/etc on the inside of the outer tube due to the stiff inner support pushing on it.
Even time I try shells things fail - though I'll admit I've never used them before.
I expect a result something like this (I've shown the red stiffener as unbent, in reality there would be a SMALL bend but in no way should it have the same shape as the outer bar)
The issue is the simulation puts them both out with the same shape, or not interfering at all. I did try bonding one edge of the steel to the inner surface of the alum, and this works but the simulation is taking many hours to run - likely due to the small mesh size to capture the thickness.
I'd like to tell it to push as hard as it takes to get me a specific deflection, is there an easy way to set that up?
So I'm back to not being able to get a result.
Does someone have a good walk through on how to properly use thin shells? If someone could model a force acting on a square tube, constrained by a pin at each end (just pressing against it) and I could look at the set up, I'd be very very grateful. Somehow I always get errors. Its pretty ridiculous, I've done countless simulations on assemblies on thousands of parts.... but this gives me fits.
