How to select group?
Hi Eng-Tips!
I need some help in journaling, I need a selection of groups. Does anyone of you know how to make a selection where you can select several groups? I need the groups to make different plots.
RE: How to select group?
NX8.5!
The problem is, when I record it, it writes out the usergroupIds which I don't know where to find...
Can you post your recorded journal, or at least the relevant section?
www.nxjournaling.com
Sure
CODE -->
Option Strict Off
Imports System
Imports NXOpen
Module NXJournal
Sub Main (ByVal args() As String)
Dim theSession As Session = Session.GetSession()
Dim workSimPart As CAE.SimPart = CType(theSession.Parts.BaseWork, CAE.SimPart)
Dim displaySimPart As CAE.SimPart = CType(theSession.Parts.BaseDisplay, CAE.SimPart)
Dim usergroupIds1(0) As Integer
usergroupIds1(0) = 1
theSession.Post.PostviewApplyUserGroupVisibility(687, usergroupIds1, CAE.Post.GroupVisibility.ShowOnly)
Dim usergroupIds2(0) As Integer
usergroupIds2(0) = 2
theSession.Post.PostviewApplyUserGroupVisibility(687, usergroupIds2, CAE.Post.GroupVisibility.ShowOnly)
Dim usergroupIds3(0) As Integer
usergroupIds3(0) = 3
theSession.Post.PostviewApplyUserGroupVisibility(687, usergroupIds3, CAE.Post.GroupVisibility.ShowOnly)
Dim usergroupIds4(0) As Integer
usergroupIds4(0) = 4
theSession.Post.PostviewApplyUserGroupVisibility(687, usergroupIds4, CAE.Post.GroupVisibility.ShowOnly)
'   Menu: Tools->Journal->Stop Recording
End Sub
End Module
This was what I recorded when I clicked on all the groups with the function 'show only'. Now I need a selection of these groups.
In the API reference, look up the CreateUserGroupFromEntityLabels Method. It sounds like it may be what you need.
Quote (API reference)
Returns a usergroup handle that may be used in UserGroup* calls and in PostViewApplyUserGroupVisibility
Thanks for your help! But with this method you would create a new group out of entities wouldn't you? But I only want to select the groups I already created. Do you know any method how I could recall the usergroupIds?
