Low temperature ceramic processing
Hello All,
Is there any low temperature processing technique by which one can fabricate ceramic with high mechanical strength? For example I have alumino-silicate crystals with avg. crytsal size of 300 nm, shaped to green body and the limit of temperature for processing is 900 °C.
I am trying to use amorphous silica with 40 nm particle size and then sintered it to 900 °C but results are not good. Does someone know what is melting point curve of silica/alumina with particle diameter?
RE: Low temperature ceramic processing
"Nobody expects the Spanish Inquisition! "
http://www.electroscience.com/ceramictapesystems.h...
http://www2.dupont.com/MCM/en_US/assets/downloads/...
TTFN
